Led lights in cockpit area
Has anyone changed the lights mounted under rear seat and by step going into cabin to led,s? They are oval, for my 2002 viper. I am not by the boat now, I would like to order some led bulbs for next weekend. Anyone know what kind of bulbs it would take ? Any info would help thanks
I changed all of mine over to Lumitec lights from the radar arch down lights, cockpit lights and installed under water Lumitec lights as well. I could not be happier with their products and great pricing as compared to other LED lighting companies. http://www.lumiteclighting.com/
I don;t have any close up photos of the cockpit lights other then the following pictures. Yes, they mount the same as the stock lights so no cutting required unless you are adding the underwater lights like I did which require holes to be drilled. [ATTACH=CONFIG]543562[/ATTACH] [ATTACH=CONFIG]543563[/ATTACH]
Try these guys. They have every LED bulb for anything. If you give them the number of the bulb in your boat, they can cross reference it and get you the one you need.
https://www.superbrightleds.com/proj...riror/top/462/
