Spectra 222 or Stryker 237?
I'm thinking about getting a PQ. Not sure witch one to get. I found a couple of them. One is the Spectra 222 and the other is the Stryker 237. The hulls look identical to each other, they both have 454's in them. The only difference is the Spectra has a Bravo1 and the Stryker has the Bravo3. Will there be a lot of difference between the two outdrives performance wise, prop selection, top end speed? Thanks.
Go with the the bravo 1 for performance . Easier to find and get props for sure and "should" be faster on top end.
The 222 looks to be a "older", dated design tho vs the 237 in my quick googling of it.
I had a 237 and it was nice.
If you see them both in person and side by side I am sure that you will see the difference.
237 is a more modern, deeper, bigger boat.
237 is closer to a 257/260 Legend.
I only had 7.4 with BIII but it did good enough for me at the time.
