Baja 232 Prop ??
Hi to all, i have a 2002 Baja 232 with a 6.2 mpi. Love the craft, it has a 19 pitch Mirage Plus prop. Does anyone know what the best prop to run on this craft. i mostly cruise around at about 4200 rpm. speedo is out so i don't know mph. wanted to get a 2nd prop in case i boo boo one up. Thanks Lynn
Why such a tiny prop what are you WOT rpm's ?? and gps speed... My 96 232 with 300 hp ran with a 23 mirage plus, which was o.k. but a labbed 24 B1 would proabably be best overall for holeshot, midrange and handling..
That tiny prop was what was on it when i got it. i will GPS it, this weekend. i want to say that at WOT the RPM is at 5200, best i can recall. Thanks Lynn....will also take some notes this weekend. Thanks..
Offshoreonly Advertiser
![Smile](/forums/images/icons/icon7.gif)
You may be on the rev limiter.
If you are looking for best all around performance especially mid range cruise speeds, consider the Bravo 1 4BL. It works great at cruise without sacrificing too much top end on your V hull configuration.
However if your not on the rev limiter, we really love the Rev4 propeller in 19 and 21 pitch. It's extremely fast for a 4BL propeller with good mid range and planing ability. It has an aggressive design with the benefits of 4 blades.
[email protected]
[email protected]
I got to GPS the 232 this weekend. 2002 w/ 6.2mpi. the 19 mirage plus is topping out at 4650rpm @ 52.3 mph
with a full tank and 2 adults.....
HELP
..... we got to do better. Thanks Lynn
![Mad](/forums/images/smilies/mad.gif)
![EEK!](/forums/images/smilies/eek.gif)
The recommended operating range is 4800-5200 RPM at WOT. So something is not quite right. When you are recording your WOT RPM, are you are trimmed for speed? This will influence your RPM. If you are trimmed for speed then we need to look at each number used when calculating slip and individually and confirm them:
Numbers used to calculate pitch:
Prop pitch accuracy
Tach accuracy
Confirm gear ratio
Verify gps
Julie
Prop pitch accuracy
Tach accuracy
Confirm gear ratio
Verify gps
Julie
check your tach. Had the same motor in my 02 252 islander. would spin the 19p to 4900 rpm's.
And mine was running 56 to 59 gps depending on conditions.
Are you sure it's a 19P? U might borrow someone elses 19p just to make sure.
i did a compression check today. had 3 cylinders @ 160psi, 4 @ 155psi and 1 @ 153psi. the plugs were in need of a change so i gapped them and put the new ones in. Can anyone think of anything else i should change/check? Thanks Lynn
