question on 353 props?
On my 03 353 Fastech with 500 EFI I am currently turnning 29 labbed Hydros (needing service) so my question is what
would the P5x's do for me or should I stick with another set of 29's. I need to get a backup set so I can send these out for service. Any advice ?
Thanks,JIm
Thanks,JIm
I would recommend one of 2 propellers both being Hydromotive 5B's. the Hydro P5 or the P5-X. Both of these propelers performed well on the Formulas. The Formula racing teams all ran P5 propellers, but have not run the P5-X on the course. We havn't seen much of them this year. But I can tell you that several OSOer's with Formulas have used the P5-X props very successfully. Hope this helps.
Julie
Julie
Offshoreonly Advertiser
![Smile](/forums/images/icons/icon7.gif)
Before buying any new propellers you need to clarify your goals.
What are the current performance numbers with the 4bl Hydro's?
We have set up numerous Fas-Tech's (including race applications) with Labbed Bravo 1's for years. Some of our current customers are running Maximus 5blade props and are seeing huge cruising improvements and stable top end numbers.
[email protected]
[email protected]
okay when freshly labbed I saw 84 gps wot 5100 rpm good number I thought now down 5 mph so would that in mind most of my boating is 4000 to wot with the occasional pokerrun so I am not opposed to keeping these after cleaned up and having another set. I would like to carry the bow a littlle higher if possible but my concern would be to achieve quicker planning and mid to upper range cruise so what size,what model and how much should I expect to spend? Please PM me as I am a serious buyer.
Thanks, JIm
Thanks, JIm
I would recommend the 5B Hydromotive P5-X. If you woud like a pitch recommendation feel to call me anytime. The cost of the P5-X is $999.99 each and they typically run great out of the box without labbing.
Julie
Julie
