Alpha SS prop question
Re: Alpha SS prop question
Originally Posted by bbladesprops
Depending on what the props pitch read at, your slip numbers are conciderably above average. If they are 21 pitch, Your under 7%. 22 pitch = 11%, still very good.
Are you sure your tach is accurate?
Props were done on an MRI
Offshoreonly Advertiser
OK, you're running great! Once you determine the top end rpm you are capable of with the boat trimmed, you will be able to decide if you want to rework these props or look towards different propellers.
[email protected]
[email protected]
Poker run this weekend........I'll try to lighten her up and go for a good WOT run
Update part duex- Ran 60.2 WOT trimmed out 4700 RPM....need more speed, However the cruise was great 45 mph @ 3500 rpm - felt like the sweet spot.
Julie- I would have to guess about 45-4700 rpm.
They are not really high performance motors small cams vortec heads.
Mfg states 5200 max rpm.
You will need to determine were the peak HP is produced if your goal is top end. There is a range for your motor, the torque band and determining were the peak HP is produced will allow you to dial her in for top end , curise or whatever your goal may be.
Julie
Julie
