baja 275
baja 275
a friend has a 2003 baja 275 with a 496 in it and a three blade 23 pitch prop
the prop doesnt seem like enough to me and his rev limiter beeper is going off a lot he says
what are most of you with a set up like this running for a prop
Re: baja 275
If he wants to run a stock prop then he could uppitch his 23P to a 24P an pull him off of the Rev Limiter. Or lab a 25P to acheive greater top end as dtsquest stated.
Julie
Julie
Offshoreonly Advertiser
Re: baja 275
Depending on how hard he is in the rev limiter, he could hit it again with a Labbed 25 Mirage. When we Lab Mirage Plus 25, it will run only 50 rpm less than the 23 box stock.
Run the 25 as stock. Get the numbers and we will do a special recipe to put him right where he neeeds to be.
[email protected]
[email protected]
