Drive shower pickup tube length
Offshoreonly Advertiser
Re: Drive shower pickup tube length
Yes it can.
Just enough tp expose the angle of intake.
[email protected]
[email protected]
Depending on the placement, angle and length, the tube can cause a ventilating issue to the face of the propeller blades.
This scenario is relatively rare.
Also, as related to performance in general, anything in the water flow creates drag.
[email protected]
[email protected]
Originally Posted by noboat
That's why I use this type of "pick up"!
Originally Posted by carney
where are you picking up water. and I also agree that the tube length has a effect on the water to the prop. I shortened the pick up and fixed the blow out.
Julie/Brett, pick up tube downstream of the prop can effect water flow to the prop? My IMCO drive shower tip extends 1 1/4" below cavation plate and is less than 1/4" from prop tip. This is too close?
