what prop does my 23 Chris craft need >
Old 04-26-2006, 12:41 PM
Default what prop does my 23 Chris craft need
I have a 23 foot scorpion 260 merc through hulls fresh motor mild mods , whale tale and trim tabs, running a 21 s/s now doesn't seem as fast as I'd like (the occasion 50 ) I'm not sure were to go next ?
scorpion king is offline
Old 04-26-2006, 06:54 PM
masi242's Avatar
Default Re: what prop does my 23 Chris craft need
Welcome, first are you hitting the optium Rpms for your engine, if if so then you are fine, if you are over revving you need to go up in size.
The best thing to do is call Throttle up and advertiser here and talk to them they will be able to help.
mark
masi242 is offline
Old 04-27-2006, 05:32 PM
throttleup's Avatar
If you can post some of your performance data I will try to assist you.
What is your WOT RPM?
What drive and gear ratio do you have?
What is your WOT MPH via GPS?
With a little data we can get started.
Julie
throttleup is offline
rgm50
Chris Craft
4
03-08-2008 09:32 PM
randall
04-23-2007 10:56 AM
97BossHammer
12-19-2003 11:18 AM
rock brown
7
06-24-2002 09:18 PM
r-boat
1
01-21-2002 12:16 PM
Quick Reply: what prop does my 23 Chris craft need
