hydromotive props
i am looking into buying a pair of quad4 props for my boat, a 32 pachanga, i am currently using mirages, what is everyone's oppinion?? it is on a 32 pachanga, speed w/ the mirages is around 70, also, how does 4 blade pitch compare to a 3 blade,i know it isn't the same in final rpm differences, can anyone suggest some props to try?? or different props? i've tried merc thru hub cleavers and didn't have any luck, the mirage seems to be the best
Offshoreonly Advertiser
![Smile](/forums/images/icons/icon7.gif)
We have set up a number of Pachangas with Labbed Mirage Plus props. The boats like bow lift until you get into the extreme speeds over 80 and there aren't many of those.
Talk to Don at West Isle Marine in BC. We've done some for him over the years. 250-656-7767.
Can't really compare pitch from 3 to 4 blade. Each propeller family is different. I think you mean if you take a 3 verses 4 blade of the same pitch, what will the rpm difference be? If they are the same diameter, the 4 blade will 100-150 rpm lower.
[email protected]
[email protected]
