Mirage Plus VS Mercruiser Quicksilver
I curently have a Quicksilver 27P I was going to have labbed.
Would I notice much difference if I purchased a Mirage Plus 27P. I understand the Quicksilver is a little more stiff?
Re: Mirage Plus VS Mercruiser Quicksilver
I would reconsider lab finishing your prop. If needed, a reconditioning should be all it needs. Typically you won't see much of a speed gain from a standard Mirage or the older Quicksilver props after lab finishing.
A Mirage Plus 27 will run about 200 rpm less than your Quicksilver.
Looks likes it time to put the old quicksilver back on Ebay
Offshoreonly Advertiser
You can gain small amounts from Labbing the Q.S. props. You need to change the Blade area and the geometry and the rewards very.
As far as the standard Mirage, we find big gains if the application has good top speed numbers with rev limiter R's and high slip % by turning them into Plus's.
[email protected]
[email protected]
2 Trick Rick
08-25-2006 10:57 AM
onesickpantera
07-16-2005 07:35 PM
