cracked blade labbed Bravo 1 32?
Originally Posted by zahndok
Good info. Thanks. Already bought a replacement. Strip, that picture could be my prop. Exactly the same crack placement and length.
I lost a blade on one it took out the gimble pin from the vibration
BBlades or ThrottleUP
Can a cracked blade that extends about 2/3 thru the blade half way down the blade be repaired? There is no visible offset at the crack. Local shop told me they don't repair cracked blades. If you can repair a chewed prop from hitting bottom, what would be the concerns with repairing a crack on an otherwise perfect prop?
