Will need suggestions!!
I'm putting together a 2005 42' Executioner with Staggered 525's with Sport-Master . Ratio 1.50 What is going to be my best prop selection for all around use. Contacted Fountain and they had no suggestions, They said that they have never tested a 42 Executioner with Sport-Masters. Please RULE out HERRING'S no BUDGET for THEM!!
Re: Will need suggestions!!
If price is an issue stock Bravo 1 props will work well for your application. The drives will have to be set at the correct height but you should be able to get good overall performance with those props.
I have major issues with slippage with stock brovo's with standad xr's I would think the Sport-Master's would make it even worse. just my .02...take a look at hydro's p-5-x's thats what I will have in the spring.....BZ
Offshoreonly Advertiser
We can supply you with both Bravo 1 and 5 blade Maximus propellers for testing. Both these propellers can be adjusted in many ways to obtain the best performance for your boat.
Give us a call if you would like to try either or both of these propellers.
[email protected]
[email protected]
