markings on merc. labbed props ?
How can you tell if a prop is labbed from merc. ? does it have a certain finish or stamped marking and were is it located ?
Offshoreonly Advertiser
![Smile](/forums/images/icons/icon7.gif)
The stampings are the ultimate way to tell. The stampings are also a code. Trained eyes can also tell simply by the finish. However, Merc originally Labbed doesn't mean currently Merc spec.
By the way, the stampings are done by hand, not cast in and vary in information and quantity
[email protected]
[email protected]
I bought a brand new 28p merc labbed prop and a demo , should both of these be labbed the same or does merc change their specs every so often ? just wanted to be sure I have a matching pair.
Merc Demo props are blue.
There is a standard Lad recipe developed for Bravo 1 props back in the 1994 ish time frame. Standard templates are still used and modified. If you order a Labbed propeller from your Mecury dealer, you will get the standard Lab. Otherwise you need to contact a facility like BBLADES to obtain custom specs.
Are there stampings on the propellers?
[email protected]
[email protected]
Let us know what you see.
[email protected]
[email protected]
Chris288
08-18-2004 02:30 PM
