Revolution 4 vs Bravo 1 >
Old 06-07-2007, 04:52 PM
Charter Member #300
Shooter's Avatar
My friend had a 24 Pantera and the Hydro was the best prop for it - in fact I still have that prop in the swap section. He soon upgraded the motor.
Shooter is offline
Old 06-07-2007, 05:06 PM
onesickpantera's Avatar
What Hydro? I tried a QIV and it worked okay. Not nearly enough bow lift though.
onesickpantera is offline
Old 06-11-2007, 08:34 AM
Originally Posted by marylandmark
You need the QIV-X. I am not a prop guy but the X is the bow lifting model...[/I]
I know the X is the bow lifter but it was a used prop that I tried.
Old 06-11-2007, 09:18 AM
Pat McPherson's Avatar
Originally Posted by onesickpantera
Will definitely post results. Suppose to be a nice weekend!
I found my Turbo 3-blade that revved a little higher than my Mirage that I plan on testing as well.
So how did your testing go?
Did you try a Rev 4?
Patrick
Pat McPherson is offline
Old 06-11-2007, 10:12 AM
Well I got to try the Rev 4 this weekend and my it was much better than a Bravo on my boat. Ran looser than a Bravo, much better bow lift and didn't lug the rpms down as much. I was actually surprised that I was able to pull the rpm I did with the prop. Very little slip too!
Old 06-11-2007, 11:06 AM
The Rev 4 seems to work well for ya.
Only 1-2mph slower than a 3 blade Mirage is really good.
I ran a 27p Turbo Fusion 4 last year which has a smaller dia than a B1 like the Rev 4. It was 2+ mph slower than my labbed B1 though. Stock vs. stock they may have been the same.
Brett did tell me he's seen that the Turbo F4 is 1-2mph slower than the Merc Rev 4.
I guess the Rev 4 is a real good 4 blade design for our old school hulls. Too bad they don't make a 27p...
Patrick
Old 06-11-2007, 11:57 AM
Yeah for a box stock prop I was impressed. Prop was very stable and carried the bow well. I think I'll grab the Rev 4 for the bigger lakes and keep the Mirage for the smaller lakes where I do mostly WFO blasts.
Hopefully they will make bigger sizes down the road.
Old 06-11-2007, 02:27 PM
So would you say the Rev 4 fits between the B1 and the QIV (or did you use the -X model?)
No, on my boat the Rev 4 has more bow lift than the Bravo and the Bravo more than the QIV. I never tried a QIVX. The Rev 4 was also a little "looser" probably because of the smaller diameter and it didn't require a lot of trim.
IMO, the REV4 is the closest to a "4 blade Mirage" prop I have tried.
Old 06-11-2007, 02:52 PM
Thanks for the info- I was getting myself confused...
I have LH/RH QIV-X 25's I got from Handfulz28 if you were interested?
Thanks. I might take you up on that RH prop!
Old 06-11-2007, 03:25 PM
I want to keep them- they work great on my boat but would be willing to ship it out to you to use for a bit vs. buying one as long as you share the data...
(This is what Mike did for me but I liked them so much he let me buy them from him, however I would not sell them or at least not seperate if it came down to it..)
No problem I totally understand it would be for testing only and I appreciate the offer!
Quick Reply: Revolution 4 vs Bravo 1
