Prop pitch question >
Prop pitch question
Prop pitch question
Old 06-14-2007, 07:04 PM
Thanks. Battery was dead so no MPH. I'll have to go out again to get some hard numbers.
jdub is offline
Old 06-15-2007, 03:31 AM
Received 1,894 Likes on 952 Posts
Originally Posted by jdub
Is there a rule of thumb on how much a pitch size increase will change RPM at WOT.
General rule is 200 rpm decrease for every 1" of pitch increase----with the same make of prop.
Griff is offline
Old 06-26-2007, 07:48 PM
Well I ran a 26 Bravo and saw 82 GPS @ 5300. At this point I would say this is the prop for me. But I am still open to suggestions on what else to run. Thanks.
jdub is offline
Old 06-26-2007, 09:43 PM
Offshoreonly Advertiser
bbladesprops's Avatar
Smile
Labbing a 28 is another option that will put you in the same rpm range (5200ish). Your current efficiancy will help to determine if Labbing is a good all around option. Your gear ratio will help to make the determination.
[email protected]
bbladesprops is offline
prostockcat
4
05-11-2008 08:45 PM
seansmp8
07-29-2007 05:29 PM
Rick G
10-07-2003 11:16 AM
jollyroger
1
06-07-2003 06:00 AM
jollyroger
4
04-17-2003 05:33 PM
Quick Reply: Prop pitch question
