A BIG PROBLEM not planning
Hi i did not use the tabs, and this week i will try 4-blade 17,5x28,cleavers and drain out 200gal, of fuel before i try it again.
Now i have put the 2 inch spacers and 4-blade 17,5x28 cleavers,the engines are spinning 3000 rpm WOT 47mph still have difficulties to plane,think the max rpm is 6000-7000 rpm on these engines, gear ratio 1,5:1 ,what to do ????.
You will definately need to try smaller pitch props. It will get the engine into its power band. I would try something in the 22-24 pitch range.
Why do you think they are 6000-7000rpm motors???? Do you have dyno sheets???? With 620hp, 5500rpms is more likely.
Don´t have the dyno sheets, i pulled out the engines and i am going to supercharge them and do the dynos.
Offshoreonly Advertiser
HP to weight ratio in theat boat should put you in the 70 mph range with 24 pitch propellers turning 5400.
Check your recomended engine rpm ratings. I think you may be a little high in 6-7000.
Because the propellers are now hooking up well enought to keep the slip % below 15, something must be going on with the engines to only allow 3000 rpm.
[email protected]
[email protected]
