Chine walking vs stock vs labbed vs diffuser ring removed B1 prop >
Old 08-06-2007, 01:55 PM
Offshoreonly Advertiser
bbladesprops's Avatar
Smile
Yes, getting on plane without ventilation. (different than cavitation)
Sometimes ambiant air will still be drawn through the drive because of the huge pressure differential. Diff. rings were started back in the outboard days of old when all exhaust travelled through the hub.
$40 to remove a Bravo diff.
[email protected]
bbladesprops is offline
Old 08-09-2007, 04:52 PM
Rob
Strip Poker 388's Avatar
Originally Posted by bbladesprops
With maximun trim angles, trying to gain that little extra rpm and speed, chining is more likely to occur. Certain hulls will also chine worse than others. X dimentions on these hulls alsoplay into the senario.V bottoms and deep X's can be the worse.
Yes, the diffusers can amplify the chining once it begins. The ramping effect the flares have, can fertilize the motion once it begins, especialy if the props are surfaced.
More seat time may allow you to control the chine before it even starts. Preventing, not driving through is the key.
Thats what I have learned ,is how to drive it, to counteract chinwalking.Like ballancing it its worse in flat water on mine and a little chop make alot of diff.
Strip Poker 388 is offline
Old 08-09-2007, 10:15 PM
Rebel_Heart's Avatar
That is exactly how mine behaves. The flatter the water the greater the chime walking, especially when trimmed out.
Rebel_Heart is offline
Rebel_Heart
Prop Talk
10
05-16-2008 08:27 PM
Fast Forward
Powerquest
6
10-24-2005 06:16 PM
tpenfield
06-04-2005 02:13 PM
ddenzin
05-27-2003 06:53 AM
mr.gov'nt
Donzi
3
09-15-2002 09:03 AM
Quick Reply: Chine walking vs stock vs labbed vs diffuser ring removed B1 prop
