what props do ı need for 35 baja outlaw with t 496 hos
hi guys i have a 07 36 outlaw with t 496 hos and only at 63 hours i have been trying my max speed on the boat but i couldnt be able to pass through 63 mph with 4300 rpm max everybody is telling me that i shoul get 26s instead of mine 28splease help me what shoul i do and if so where can i get the best 26s but not labbed becouse i am gonna use it at mediterrenian very salty
Offshoreonly Advertiser
![Smile](/forums/images/icons/icon7.gif)
For max speed go to 25 Mirage Plus propellers if 4300 is all you can get out of her.
My suggestion would be, if you want the 4 blade mid range qualities and drivability, we can do a customized set of 26 Bravo 1 Labs for you with a chrome bumper HI-gloss to prevent corrosion.
[email protected]
[email protected]
I know a man in Sweden who runs a 35 Outlaw, 496 HO's 2006. He uses Bravo One 28P (not labbed) and the boat tops out at 75 mph @5100 on the GPS.
Good luck,
Markus Tell
Good luck,
Markus Tell
Buggy
THe 496's will get a little more RPM's once you get above 100 -125 Hr's
A friend have a set of 26" hydros that might work well.
I got similar issues. Can't get past 65 MPH with a 33 footer.
I have a set of 24" bravos. YOu might want to try the 24" and have them labbed and add a little more cup to them. THe 24's are priced great. I use 26's B's with same speed as the 24",s.
The 36 Outlaw went out of production a couple of years ago.
I used to run a Baja 342 Performance 496 HO's, 2006 and reached 73 mph with Bravo 26 standard.
Another guy in Sweden runs a 33 Outlaw 496 Ho's, 2005. He hits 78 mph.
Last season I put Whipples on the engines and changed props to Throttle-Up CNC 5 blade 29P and hit 84 mph!
Regards,
Markus Tell
Regards,
Markus Tell
Thanks Julie!
Yepp, I traded the Baja + change for the Fountain. It runs 90 mph @5200, Mercury 600's (93 mph @5350 according the the Fountain sheet, downhill, homesick and the sun in the back). I always have plans for my boats. When I get to the props I will contact you. What a ride the Fountain is, fast as hell and smooth as silk.
Paradox
The whipples are great! I estimate the output in the neighborhood of 550 hp since I used the stock exhaust. Whipple claims 600 hp, but then you need headers.
I have run 70 hours with the superchargers without any problem at all. Just change the oil and filters more often.
A simplier way is to go for headers, 1.8 roller rockers and the Whipple stage 2 rerprogramming of the ECU's. In theory you could get near 500 hp.
Regards,
Markus Tell
Paradox
Regards,
Markus Tell
