Arneson Props
Lunatic Fringe
Does anyone on the board have or know someone who has a set of 35 or bigger 4 blade or 5 blade props to fit an Arneson big shaft. The staft is the same diameter as a #6 but it has 25 splines instead of 26???? I am spinning 16.5 X 33 4 blades to 6000 RPM with more throttle to go.
HELP
HELP
Jeff, gibe me a call at the shop - I have a set of # 6, 35x 16 1/2 five blades from Showtime - give them a try before you spend $$$$ - .........I busted 150 mph at the radar run and I did not get a t-shirt ??? - I need to find new friends that care
James
James
Lunatic Fringe
Jamie! Wrong spline, I have the Arneson spline 25, not the #6 spline 26. Thanks for the offer. WE care !! Every time i walked over to you on saturday, you were too busy with the ladies to speak, sounds like Key West.
HAR
Offshoreonly Advertiser
![Smile](/forums/images/icons/icon7.gif)
Find some big pitch 19 spline Mercs and have it broached. We used to do it at Merc Racing but they have since stopped the service.
[email protected]
[email protected]
Lunatic Fringe
I have searched this forum and others and there does not seem to be many big pitch 4 blades even of the 19 spline variety out there. I may have to go to a merc 26 spline shaft in the arneson to solve the problem.
While a 26 spline shaft will give you many options for props your 25 spline shaft is not a problem for a new set.
A new set of 25 spline props won't cost you any more than a set of 26 spline. The problem is most prop manufacturers may consider them as custom and if the rpm wasn't right they would not be returnable.
Call Rick at Arneson.
I know he has 19 spline to 25-26 adapters but I don't think he has what you need.
[email protected]
[email protected]
jeff32
04-01-2008 11:49 AM
