Broken Bravo 1
Well, Sunday afternoon turned out to be a bit more eventful than I had planned. My nice shiny Bravo 1 26p lab finish prop decided to throw a blade off out of the blue.
I noticed about a 1 1/2" crack in the same blade about two weeks ago and took the prop to our local prop guy (who I will say usually does a stellar job). I could only guess it was caused from stress, as my blades were pretty thin, and I wasn't sure about the age. I thought it was a little strange, but wasn't too concerned. The prop guy was able to repair the crack and give a nice brushed finish making it look brand new again. He also added a bit more cup which improved the planing performance and acceleration dramatically. BUT, after only maybe 2 or 3 hours on it, the same blade flew off. Coincidence?? I think not. Don't worry, pics to follow. I'll show you all my nice new expensive paperweight.....
Anyway, I obviously need to replace it, and I'm not sure which route to go. I've got a '96 27 Fever with mostly stock 502 Mag MPI with EMI Thunder headers, light pulleys, a crossover, and a nosecone. I liked the way the 26 B1 ran, but I was only able to pull about 4,600 rpm out of it and it was pretty slow out of the hole. I've heard great things about the Hyrdomotives but I need some pointers about which prop replacement will be best. Like I said i could pull about 4,600 rpms and got about 69 in perfect conditions with the B1, and it was a pretty solid prop (while it lasted). I wouldn't mind turning a few hundred more rpms and perhaps more top end. Would a five blade be a bad route in a lower pitch? Should I stay with 26, or maybe go down a bit?
Any help is appreciated. Thanks guys.
![EEK!](/forums/images/smilies/eek.gif)
A Hydro QIV might work well for that boat. You could try between a 24 to 26 inch prop. Don't think a 5 blade will be the best for that hull, but you never know until you try.
A QIV 25 will be a great starting point. It is equivalent to your B1 26, but a better stern lifter. If you are still light on rpms, you can get it labbed to pick up a couple hundred rpms.
Your X dimension is probably too deep for any help from a 5 blade, unless you get shorties, blah, blah, blah.
Carder
Carder
Thanks guys!
That's kinda what I was thinking on the 5 blade, and until I get a shorty, I don't think I'll try it.
I'm thinking a Hydromotive QIV 24 might be the best bet. Perhaps get a little better out of the hole performance and turn a couple hundred more rpms.
Now, does anybody out there have one......
![Drink](/forums/images/smilies/drink.gif)
