Surface Drive Prop Rule
Surface drives give high slip numbers on most hulls other than extremely efficiant hulls. ie catamarans. People will argue that but I see it every other day. They do have their advantages though.
Keep the 17x29 4 blades and let us have a crack at them. I know we can improve the slip and speed numbers.
![Cool](/forums/images/smilies/cool.gif)
Bret,, thats what i ment,,,, he runs 17 X 23 !!!!!!! To small .
But i need to actually have you take a look at my prop.
My slip # is up like 18-20 % ????????? And the hull is perfect straight.
![EEK!](/forums/images/smilies/eek.gif)
Brett, or DD with a 1:54 ratio trans and an 18% over drive/drive "for round # sake" @ 6000 rpm engine speed, the out put of trans. would be 4000 that is to say: 3 rev. of engine speed produces 2 rev. of trans. out-put X 1.18 would produce a prop. shaft speed of approx:4720 with a 17x23 wheel and say a 10% min. slip what do you guys fig. for mph ? ps: just 4-kicks and giggles Ritchie Sutphen says that his boats, back in the day ran excellent w/Kaama surface drives ! Thanks again.
car biz, send me a PM w/price if u-wish on the 16.5x 24's, I might consider a spare set, thanks for the photo. so your look-in for a long style hub/19 spline shaft, same as a #3 uses around a 17x27 or so correct ? ps: u-puttin more hp in that hull ?
dd thank you very much I will chase u-down in KW
