LH/RH vs RH/LH prop install on twin screw
As far as drive showers, just get the new style Simreks and you don't need to drill anything SIMREK Multiport Drive Showers will cool your Alpha or Bravo stern drive by 60 degrees.
imartin (04-08-2024)
Your props are spinning out. The LH prop is port and RH prop is on starboard.
Griff (04-10-2024)
Me and buddy both tested this at the same time and neither one of us noticed any difference. Same exact top speed. Same manners pretty much everywhere. You only need to shift backwards for the "test". If you decided to switch you just adjust accordingly and then shift normal.
