Bravo 1 Prop Corretion
I have a pair of Bravo props, and I'm getting suggestions to have them "Corrected". Meaning, they believe that the props come from the factory with the blades not all matching in pitch. Could this be a source of my high slip numbers? And what other options are reasonable to reduce slip numbers?
I’ve been told Bravo-1 is overstated in their pitch. So a 24 will be closer to 23 actual pitch. That’s gonna affect your slip calculations.
Just what I have read……on the internet.
They're not in Cleveland anymore. They're in Lakeside Marblehead now. The just got operations underway a few weeks ago. They acquired Sante Marine Propellers.
as stated the bravo pitch is high than the trued pitch,,,,,even mercury in their litature tells u if running a rev4 or tempest,ect to add higher pitch when go to a bravo from what pitch was running on the other props,,,
so check slip calculator using 1-2 pitch less that whats on the prop
bblades and fj propeller both true up them props daily and redesign blades and bell better matched for your boat
when u tell them the slipo and how boat riding characteristics
