26 Outlaw 496 mag ho prop questions >
Old 10-10-2024, 12:44 PM
  #31
Originally Posted by c0ncEpT
I hate to sound like a broken record but get a box stock 28p B1 for that thing.
Fountain built all of their late model 496HO powered 27's and 29's with 1.65:1 outdrives. They used 28p or 30p depending on the drive height.
My old 2004 27 used a 30p and would spin right to around 5,000rpm and 69mph.
A 26 Outlaw is closer to the size of a 29 Fountain just without the step. It will likely want a 28p with the 1.65:1 drive in that hull.
Thats what im going to do. I really appreciate all the information from all you guys.
Seth437 is offline
Old Yesterday, 01:07 AM
  #32
Received 1,993 Likes on 995 Posts
Originally Posted by Seth437
That all makes sense. I will reach out to them. Is it worth it to do a gear change to bring this to a 1.50 ratio. Would that make any significant gains in performance
thank you all for the help. It is much appreciated
BBlades has a prop loaner test program as well.
IMO, not worth changing the gears. You should be able to find a prop that works. I have 1.36 drives on my boat and BBlade labbed 24's. My same boat/power with 1.50's would be running 26's or labbed 28's. I actually ran with a boat like mine years ago with almost the same power and 1.50's and we were right next to each other in a poker run.
Griff is offline
