It looks like its turning into a full resto!!!
#32
LOVE the diamond plate!
#33
As for the engines I will be keeping with the 598’s, utilizing all the existing internals except for the damaged pistons. I also went with different ring package this time. Another thing, I decided to forgo the B&M 420 supercharger idea and go with Blower Shop 14-71’s. I also updated to shaft rockers. Setting up the geometry on the shaft rockers was not just bolt on and go. The rocker stands needed multi axis machining for the fit I desired.
![](http://i1202.photobucket.com/albums/bb366/jbeson/Picture336_zps56dd2e22.jpg)
![](http://i1202.photobucket.com/albums/bb366/jbeson/Picture378_zpsf95dbbc0.jpg)
This last pic is me lugging the engines back and forth to the machine shop. Not the most desirable spot to be working (on the tail gate) but hey it worked!
![](http://i1202.photobucket.com/albums/bb366/jbeson/Picture387_zps176f6933.jpg)
#35
#36
Throughout this build we are custom building a lot of the parts. We've made various brackets for the ECM and electronics, along with custom fuel injector plates and fuel rails. These plates place the injectors at a 12.5 degree angle in the plate. Not sure if there will be any positive impact but it didn’t seem to make any sense to have the fuel spraying directly at each other. We are currently in the process of building custom water pickups and sea strainers. I will post pics in a couple weeks once some more of the components to build them are completed.
![](http://i1202.photobucket.com/albums/bb366/jbeson/Picture327_zps040b7525.jpg)
![](http://i1202.photobucket.com/albums/bb366/jbeson/Picture328_zps43b1f73f.jpg)
![](http://i1202.photobucket.com/albums/bb366/jbeson/Picture326_zps2f56d0fc.jpg)
![](http://i1202.photobucket.com/albums/bb366/jbeson/Picture337_zpsccd2a2e6.jpg)
![](http://i1202.photobucket.com/albums/bb366/jbeson/Picture318_zps0883a9b0.jpg)
#37
The pic below shows kind of what stage the engines are in currently. There has been a little bit more progress than what is shown in the pic. The reason for the holdup was due to not knowing which drives I was going to go with and I have found in order to rig the engine making brackets and such you really need to know what components you are wiring and plumbing around. I ended up finding a pretty good deal on some used Arneson Bravo Conversions that are needing of a severe refurbishing. I ended up setting the bottom of the boxes 1 inch below the running surface of the boat at the drive centerline.
![](http://i1202.photobucket.com/albums/bb366/jbeson/IMG_1059_zps56331d47.jpg)
![](http://i1202.photobucket.com/albums/bb366/jbeson/IMG_1139_zpsccbd9b6b.jpg)
![](http://i1202.photobucket.com/albums/bb366/jbeson/IMG_1150_zpsca6e7441.jpg)
#38
If those boxes don't work out for you I would be interested in them. Did you coat the diamond plate with anything to protect it? Nice work, I wish I had access to a cnc machine. Randy
#40
Thanks Randy. It’s very nice having a CNC and even better having an excellent programmer available to me, I kind of married in it to. LOL! My father in law teaches me as we go but you can't learn 30 years of experience in a few hours. I come up with all the designs since he’s not in the boating stuff. As far as the boxes go I am hoping they work out since I really have not thought of a plan B at this point. I haven't coated the diamond plate with anything yet, any suggestion on what to coat it with?
