Price for cabin restoration??
Just trying to get an idea of what it would cost to replace the glue in headliner and sidewall carpet, recover the facing couches and v-birth pads with new vinyl on a 28' sport boat....
Hello I just replaced everything in my boat. Donzi 25zx. 3 vberth cushions were 700 and cabin interior was about 1900. I live in Jupiter also. You are welcome to look at my boat as there are a few things you may want to see and change. The heat makes it diificult for ceiling liner to stay up. Carl 5612622275
Something to consider about re-doing the headliner, you may want to glue/epoxy thin furring strips to the deck, then make your ceiling in panels that you can then screw into the furring strips, or put under a trim strip you screw into the furring strips.
Just a suggestion, that's how I did mine and it turned out pretty good, but I still had the vinyl fall off the panels from not using enough glue. I'm going to redo them with lighter hull-liner I used on the sides as soon as I get around to it. I can send you some pictures if you would like.
C_deezy has the right idea. As far as looking at my boat, i have not put my outdrive on yet so it is not ready for the water. It is at Loggerhead on Donald Ross rd. Give me a call if you would like and we can meet over there. i left you my number in another reply
Carl
Carl
Might take you up on that if I don't splash on sunday. I would love to hit the water but I hate going on holidays with all the crowds!!
