Newbie 21' scarab build
Watching this one also. Curious on more info with the 5.3 LS setup. What does it take to swap to the 5.3 from a 350 setup? Flywheels, flywheel housing, motor mounts, exhaust, etc. I have twin 350's now and am in the process of building new plants for the future like john has (Sprink on the formula section). One short block is done minus cam, getting ready to take other block in to be machined. Always thought about upgrading to LS series, but I do not know what it would take to change over.
Sweet. your post tempted me register here and this is my first post. Ive got a 89 checkmate 23' that i put a 5.3 in this summer. its running good but i need to get the ecm tuned. its only running about 58mph on gps. i detonates real bad at 4800rpm and stops pulling. you will love the boat with that motor. go efi if its not too late. i hook you up with tips if you want. i went with closed cooling also to save the aluminum heads. going out on it now, ill try to post some pics later.
im jealous! im sitting here looking at a empty bildge. LMAO. yea post some pics!
here the manifolds. http://www.skidim.com/products.asp?dept=1157
got a little done hope to have gimble housing on this weekend. here where im working
got bilge done and painted. used rustoleum white.
gimble housing from old boat gonna clean up and rebuild
waiting to find a harmonic balancer for motor need it to align the from cover with the seal.
im planning on running raw water cooling using the alpha pump for now. the harden marine sea water pump looks great but at 800 bucks i dont see it necessary right now. man those manifolds are cheap. are you eliminating the neutral interrupt switch?
Yea I saw that on Harden site that thing is sweet. Idk what I'm gonna do about the interrupt switch guess il call msd. I'm thinking beaking ground to the coil packs but I haven't looked at it yet.
I love this thread!!! When you do decide to go Bravo...save a bunch of $$$ and use a crank driven pump. I used two on my Formula twin MR/Bravo conversion...very simple...works great.
The intake ports on those LS heads could swallow a pack of cigarettes!!
