carbon fiber look
Neno the mind boggler
certainly, appearance type cf is easy to work and drills /cuts a lot like fiberglass. the twill weave fabrics generally used in parts that require "the look" are non structural and if used just at the surface wont really affect how it cuts. keep in mind hybrid fabrics, the ones that are red, yellow, green, blue etc with black are kevlar and those can be difficult to cut.
08 OPA High Points Champion
Here is a couple links from my bookmark files.
http://www.rockwestcomposites.com/br...Fezm7AodFAYAzw
http://www.dragonplate.com/ecart/categories.asp?cID=32
Thank you
we drill and route fiberglass laminate all day long,, making printed circuit boards. the drilling is thru thin copper clad (0.0007" to 0.0014") thick.copper and then laminated fiberglass that is much thicker
Thank you
Jim
I own HydroArmorinc.com. We are the largest hydrographics company in the area, offering custom carbon fiber patterns and many others. We are located in Queenstown MD. Call me at 443-871-2955 and we can discuss any patterns you may be interested in. Also look us up on Facebook to see some of our projects.....
John
HydroArmorInc.com
443-871-2955
John
HydroArmorInc.com
443-871-2955
