Restore candidate
Restore candidate
I have this 1986 Sleekcraft enforcer that I got cheap because somebody had not paid their inside store fees for a couple years. It was a lien sale.
It is 28 feet and has twin 330hp 454's with 1.32 gear ratio alpha's.
If the boat seems worth while to restore, my plan was to sell the 454's and put a couple of nice 383's with aluminum heads and aluminum exhaust to lighten the load.
I have never done fiberglass work or restored a boat.
I am committed to replacing the transom if needed and am willing to also replace the parts that the engines mount to if they are soft and I think they are. I am not willing to cut the floor out and replace stringers up towards the front of the boat. If it needs that, I'll part it out and then buck it up with a saw and take it to the dump.
I would like to pull some wood out of a few places with a hole saw to see what I have and would like to start with the stringers because if they are bad, I am not going to go any further. I was just going to pull out like a 1 inch core and then replace with with a dowel and epoxy.
My question is, are thevertical boards that make up the sides of the ski locker in the floor the stringers? They do not line up with the fiberglass covered wood that the engines mount to.
Thanks,
Russ
Thanks,
Russ
On the question about ski locker sides being stringers, there is no way to tell without getting a look under the floor. Stringers on opposite sides of bulkheads/separate compartments do not necessarily line up with each other down the length of the boat. Engine compartment stringers very often are different from the rest of the boat to accommodate engine mounting.
Get that corona out of the boat........
Well spotted ^^^
Thanks for the input.
Alpha drives behind big blocks are a hand grenade with the pin pulled. They were a horrible combination that was (thankfully) only offered for one year. I'd pass.
