Scarab 29 repowering
Is it possible to send me some pictures of your engines I do not know why the guy from procharger was not sure if they fit.
By U boy which company are these engines will be available from?
Marine Power is marinizing the new corvette engine. I know there is a few guys testing them out on the racing circuit. I'm not sure on a date that they will be comming out but sounds like a good package.
Isn't Raylar developing a 550hp all aluminum small block 427? That would be a huge jump in power along with a significant reduction in weight. You would be both more efficient and faster. Not sure the cost, but likely not cheap.
scarab
Good luck with the repowering make sure you use a good shop that can do the install right I'm having a hell of a time with my engine redo I put on new heads and the 5 psi pro charger and its still not right yet started in January
