Back from the Dead; '81 Scarab 38 Resto
#1381
No I haven’t run the steering yet, haven’t gotten my steering hoses made yet. But this same setup has been run on a lot of other boats so I expect it to work fine.
#1382
Ya, I knew the answer before I asked it.......just looks like it would bind in my simple thinking.....boats turning out awesome
#1383
Haven’t had time to work on the boat lately but did some surgery on the winch stand on the trailer today. I lowered the winch and the bumper pad bracket and extended it backwards. I plan to float the boat soon before I finalize the welds and paint this again. This trailer was originally built for an outerlimits 42 footer
The winch is higher than bow eye, helps get boat seated all the way up without cranking down loading the tongue only to find out it's still 4 inches away from the bow stop when the winch is unsprung on level ground
The bow stop is low enough to not hit the rub rail on the way on/off.
this is the year buddy you got 5 months to wrap it up, quit working on all those crashed cars they're slowin ya down
MikeScarab28XLT (12-24-2022)
#1385
Thanks a lot. I hope it’s pretty close. You’re right the shop does interfere with my hobby. 😂
We were able to work some today although I didn’t get much done. My plan was to swap the out drives so they’d be turning in instead of turning out. I was advised that turning in is the best way to go with my application.
I also planned to grease the u joints while the drives were off (I had forgotten to get this done while it was apart) as I couldn’t quite get to the fittings with the drives on the boat. I finally got the drive pins out (the port one gaulded and took a good hour and a half to work loose). I pulled the starboard drive off the boat and was ready to grease the joints, I then broke my only grease gun so had to run to town buy another. Finally found a pneumatic one at Oreillys, get back to the shop, naturally the air fitting is not the same as what we use, and yes it also gaulded coming out. Finally got that fixed up and lubed the starboard u joints. I gave up and went home after that.
On a positive note Shon did get the nav lights going. They are led and put out a lot of light. I like these bow lights better than the later ones on the deck. Also got a nifty underwater led drain plug at the stern..
rak rua (01-03-2023)
#1387
Rik at arneson configured this setup for me. The “obsession” and “all fired up” scarabs look like their setups have less angle than mine does..
#1388
But have you ever seen the extreme mechanical disadvantage some dump bed scissor mechanisms have in order to obtain lots of travel out of a short stroke cylinder?
It's boggling and proves the force of hydraulics.
And proof in theory is Mercury's ITS transom.
The steering cylinders have no or minimal angle to the drive when it's straight.
hogie roll (01-25-2023)
#1389
At first glance I'm with you.
#1390
On the v bottoms running Arnson's if you have the steering rams on the out side they drag thru the water we did a 38 fastec Formula years ago that had the rams on the out side and the dragged so badly that the boat didn't run worth a damn. We got with Rick at Arnson and moved them inboard and the boat came alive.
The following 2 users liked this post by Team Archer:
hblair (01-03-2023), hogie roll (01-25-2023)
