Back from the Dead; '81 Scarab 38 Resto >
Old 01-07-2018, 04:12 PM
  #301
jeff32's Avatar
Moving along well! Keep it up!
jeff32 is offline
Old 01-07-2018, 06:26 PM
  #302
that's good news about the deck being cored with divinycell.
you are moving fast and it looks real good.
what are you going to core that deck section with ?
are you going to tab the hull and deck together ?
outonsafari is offline
Old 01-07-2018, 07:31 PM
  #303
hblair's Avatar
Received 1,497 Likes on 330 Posts
Thanks guys. The front of the deck (forward of the fairing) is all divinycell and has no damage except for the center where the bow rail bolts to the deck, there is a wood strip there and it is at least partially rotten, it will be a challenge to repair, because it is underneath (above when deck is right side up) the divinycell sheets. I will have to cut open the divinycell to access the valley below where the rot is located, then reglass the divinycell when done.
This is an area where I guarantee all scarab flat decks are going to be rotten, unless they have been kept inside their whole lives. If you can pick up your bow rail at the attaching points the wood is rotten, unless of course they didn’t install a nut at the factory, which one of mine was actually missing lol.
hblair is offline
Old 01-07-2018, 07:33 PM
  #304
hblair's Avatar
Oh yeah, as far as tabbing the deck and hull together prolly not. I’ll prolly put it back together like the factory, but have been thinking about a different rub rail.
hblair is offline
Old 01-07-2018, 07:38 PM
  #305
hblair's Avatar
Oh yeah part II, sorry yes we’ll be coring it with wood, in the photos of the deck above you can see where we cored it back with the 6”x6” plywood pieces. It was 1/2” thick from the factory, I had 5/8” laying around and we decided to do it with that. There’s a good bit left to do as about everything rear of the fairing is rotten.
hblair is offline
Old 01-07-2018, 08:05 PM
  #306
Rookie's Avatar
Received 1,296 Likes on 630 Posts
After beating on my Panther for years in Lake Michigan, the hull/deck bolts started snapping. I removed the rub rail to replace the broken bolts. Before tightening the bolts down I filled (caulked) between the two with West Systems Six10 epoxy. This really stiffened up the boat and improved the ride in rough water and the sidewall flexing was eliminated.
Rookie is offline
Old 01-08-2018, 03:34 PM
  #307
hardest part about that raised center section will be crawling up there to do it, deck should be supported well.
what i would do is measure it length width height on the top of the deck, make notes of the measurements in relation to 1 hole
from each connection point, and transfer it to the inside.
snap 2 lines front to back for width (minus 1/8 -3/16 on each side for glass thickness)
set the depth on the circular saw and go for it, multiple cuts next to each other and the wood chips right out.
if the center section has a change in height (on the outside), tape it off on the inside and write STOP on it
once you have a section cut and cleaned out change the saw depth and cut the next section.
wrap up the clean out with tool of choice, but the for initial cut, the circular saw is fast and easy.
Old 01-13-2018, 07:26 PM
  #308
hblair's Avatar
It’s been a real busy week. Haven’t done much to the boat. Today Brian got back there and cut a lot of the core out of the rear area of the deck. There’s a lot of upset Canadian ants eh. I bought another Sawzall, $79.00 at Lowe’s. A boat idiots best friend...
Back from the Dead; '81 Scarab 38 Resto-36323acf-ca09-42a8-887f-df17dfe393f8_zpsudautwnx.jpg
Back from the Dead; '81 Scarab 38 Resto-b3251507-ae1a-40f4-aae9-005763674acb_zpswfwnmv8x.jpg
hblair is offline
Old 01-14-2018, 08:39 AM
  #309
Amazing job you guys. Its inspiring and makes me want to find another project!! cheers.
1990LarsonSenza250 is offline
Old 01-14-2018, 11:31 PM
  #310
hblair's Avatar
Got some more done this afternoon. About 90% of all this is rotten. Water came thru the gunnel upholstery, engine hatch hinges, and cleat holes in the deck. Of course no traces of caulking found around those fixtures. Will be nice when this is back together knowing all the rot will be gone...
Back from the Dead; '81 Scarab 38 Resto-58bef285-81f6-442b-9e1d-c80b3a0d7391_zps8vriboyc.jpg
Back from the Dead; '81 Scarab 38 Resto-b2cc65e3-cc5a-4152-989c-ca2476012e69_zpsd2nralgn.jpg
Back from the Dead; '81 Scarab 38 Resto-cebe4075-94e7-4891-ba85-9fda8b8f7a6c_zpspiojsqck.jpg
hblair is offline
