Back from the Dead; '81 Scarab 38 Resto
#311
Slow go replacing rot around the rear area of the deck. This is going to take several applications of glass and resin. I’m going to spend some time getting all this straightened out. There’s some cracks in the gel coat around the engine hatch area as well as a few busted places, and some old screw holes for boat cover buttons from long ago.
I’m going to have my hatches open together with the hinges at the rear. With this in mind I decided to go ahead and remove the two notches at the front and rear of the opening that must have been for a center bar. I will be filling these notches with fiberglass. Also I had to used many clamps and an aluminum bar to clamp the area behind the rear seat back in place as it had gotten out of shape since I had the deck pretty much resting on it the last year and a half.
#312
Heath do me a favor bond the hull deck joint with an 8 inch wide 1708 tab you will be repairing the joint all the time if not we tab all of our hull and deck joints. Regards Dan keep up the nice work.
#318
Thanks for the input Dan. I’ll do that. If you see anything else you think I need to address let me know.
edit: we ARE talking about on the inside correct?
#319
Didn’t have much time to work tonight, I covered the left entryway with 1708, was able to glass the joints undrneath. Should be much stronger than factory. I was shocked this piece wasn’t even rotten originally...
the original step iece was just tabbed in, and not glassed underneath. Surprisingly not rotten...
