Back from the Dead; '81 Scarab 38 Resto >
Old 07-06-2019, 12:50 PM
  #611
bck
Charter Member#568
bck's Avatar
As far as not being centered, you steer with your left anyways so it's centered with your left arm. Right?
Straight bottoms and flat decks
bck is offline
Old 07-06-2019, 01:10 PM
  #612
Agree. The original weren't centered either.
'80 Scarab Kaama
akattack is offline
Old 07-08-2019, 04:10 PM
  #613
hblair's Avatar
Received 1,391 Likes on 295 Posts
Good points and thanks for the photo.
hblair is offline
Old 07-09-2019, 08:48 PM
  #614
hblair's Avatar
Lots of sawing and trimming glass this afternoon. Last bits of rotten wood removed from the boat. Started cutting engine stringers.
hblair is offline
Old 07-12-2019, 08:23 AM
  #615
hblair's Avatar
Fitting everything and trying to plan things out in my head. I’m leaning towards hanging my trim & tab pumps off the bulkhead. Otherwise I’ll have to put platforms back on each side. The advantage to having them on the bulkhead is they stay dry.
hblair is offline
Old 07-12-2019, 06:30 PM
  #616
Team Archer's Avatar
We stack them on the out sides of the bulkhead that way the stay dry and easy to check. Regards dan
Team Archer is offline
Old 07-14-2019, 05:06 PM
  #617
hblair's Avatar
After spending much time on measuring I figured out how wellcraft did it. They put the stringers in the ballpark THEN drilled the offshore mounts to make up the difference. Notice this original offshore mount almost has the holes drilled off the edge of the mount!
hblair is offline
Old 07-15-2019, 07:24 PM
  #618
jeff32's Avatar
Mmm... measure twice, cut once!
jeff32 is offline
Old 07-15-2019, 11:32 PM
  #619
hblair's Avatar
Tonight more messing with the engine stringers then we spent sometime repairing some of the deck cracks. also put some of the Arneson hardware together..
hblair is offline
Old 07-16-2019, 07:01 AM
  #620
Knot 4 Me's Avatar
This thing is going to be so bad arse when done.
Knot 4 Me is offline
