Back from the Dead; '81 Scarab 38 Resto
#641
Thank you guys. We’ll get there at some point lol. Trent has made some progress on the bow. It will be finished in gel. The bottom of this boat will be all gelcoat.
Ok, I know this is controversial but I made the decision to go with a one piece engine hatch hinged at the rear. I just dig it too much. I prepped and bonded the top together with two layers of 1708, then removed it from the boat and put the bottom together with three staggered llayers of 1708, then put it back in place to harden. It fits well, and maybe a bit overkill but I want to be sure it would be strong enough...
#642
Did some more today. There’s a lot of trimming around the edges to be done. Also looking at some hinges. Does anybody know of any good heavy polished ones? These are 6” long on e-rigging.com. I like this style...
#643
Heath tell me why you chose to joint them together... you had two smaller hatches light enough to side lift them by hand, also i think that made possible engine removal reinstal easier, and now you have one big and heavy one, you will need an electric hatch ram, and need to pretty sure take it off for engine R&R.
i am not judging by the way, i was thinking to swap my one hatch on my cat to 2. Side opening engine hatches !!!
#644
If you go side opening clamshell like on my 30’, if you have the factory manual spring type stays, you’re a heavy wave or wake away from the hatch suddenly popping you in the head. (Happened to me many times). If you go with clamshells with electric closures, they look to be in the way to me. I plan to make these with a removable hinge pin so two guys can pull the hatch off the boat for any maintenance work. I think it’s going to work out ok. I was planning on an electric ram for this anyway.
#645
I need an electric ram for my boat. Being an engineer, I was just certain that I could find a ram that would work without paying the big $$ for one from the usual Marine sources.
What I learned is the marine rams are much faster than the ones available elsewhere. They must have special motors. The generic ones (linear actuators, as used to pivot solar arrays) move much slower, have smaller motors and lower gearing. They would take over a minute to open. Aargh!
I also wonder if the marine ones are ignition protected, like alternators and starters. If so, they would be worth the cost. Beats going boom.
#646
I also wonder if the marine ones are ignition protected, like alternators and starters. If so, they might be worth the cost. Beats going boom.
#647
this style hatch hinge is pretty common, don't know if it will work for you
#650
I am also a fan of the single hatch. I don't remove my hatch when pulling engine. I just lay it back and tether it.
