Back from the Dead; '81 Scarab 38 Resto >
Old 08-24-2019, 03:58 PM
  #651
hblair's Avatar
Received 1,497 Likes on 330 Posts
More done today, spent time fitting the hatch, installing hinges and sanding the transom. Should get the transom in primer next week. Turns out these are the same style of hinge as the star 1 boat has.
hblair is offline
Old 08-25-2019, 05:50 PM
  #652
Rookie's Avatar
Received 1,306 Likes on 636 Posts
My hinges are mounted on the inside of the lip that the hatch sits in. You can't see them.
I'll see if I can find a pic.
Post 165 shows where my hinges are affixed to the boat. This is my Active Thunder but the Panther is the same way.
https://www.offshoreonly.com/forums/...rogress-9.html
Rookie is offline
Old 08-25-2019, 06:00 PM
  #653
Rookie's Avatar
This is my AT but you can see how the hinges are mounted.
Rookie is offline
Old 08-25-2019, 06:14 PM
  #654
hblair's Avatar
Thanks Rookie, I briefly considered going the hidden hinge route, but due to the upward crown of the hatch and deck in the center in these scarabs, the pivot point of the hinges would have to be pushed back and up considerably to keep the hatch from touching the deck in the center. As it stands now, with these hinges, it’s pretty close in the center and that’s with me modifying it a good bit. Here’s star1 with these same hinges...
hblair is offline
Old 08-25-2019, 06:47 PM
  #655
Rookie's Avatar
Gotcha. My Panther hatch is mostly flat and has a sun pad so crown is a non-issue.
Rookie is offline
Old 08-27-2019, 06:52 PM
  #656
hblair's Avatar
A few coats of polyester on the transom. Good to see it all the same color. Still working filler on the hatch. Slow go...
hblair is offline
Old 08-27-2019, 07:34 PM
  #657
jeff32's Avatar
really starts to look good in one color in fact ! Nice progress !!! keep it up !
jeff32 is offline
Old 09-06-2019, 11:19 PM
  #658
hblair's Avatar
Finally got some polyester sprayed on the hatch. Trent finished working the glass and sprayed some gel on the bow.
hblair is offline
Old 09-07-2019, 03:39 AM
  #659
rak rua's Avatar
Received 1,168 Likes on 499 Posts
Love the hatch. From the distance, it'll look original but up close, it'll look better than original (No mis-aligned gap down the middle).
RR
rak rua is offline
Old 10-05-2019, 12:38 PM
  #660
hblair's Avatar
Haven’t really been able to work on the boat much lately. My dads health had been bad for a while, and he passed away, his funeral was two weeks ago today. Gonna miss my dad. I was hoping to take him for a ride in this boat when it was done. Although that’s not gonna happen, it’s good to not be worrying about his health anymore.
Weather is supposed to cool down in Alabama next week and I plan to up the progress this fall. I did spend some time recently sanding on the transom...
hblair is offline
