Lab Finishing
Lab Finishing
We have perfected the Bravo one four blade to run hard on the scarabs,WE HAVE DESIGNED THE BLADE CONFIGURATION DIFFRENT TO OBTAIN AS MUCH AS FOUR MILE PER HOUR ,CALL TODAY TO GET THE LAST FEW MPH OUT OF YOU STOCK PROPS/Darin 281-580-7767
Re: props
Originally posted by N2BOATN
ok what is the price?
what I am currentlly running are 23 Bravo 1s three blade on a 29 footer w/ 350 mags
all four blades props are called Bravo-one(these props are for the alpha or Bravo out drive ,and all three blades come in the pitch increments of (example)19,21,23,25,27,and so on all four blade props are in increments of 22,24,26,28,30 and so on .So being that you have 3 blade Mirage props is fine they run fater than a four blade in most cases.the price to lab finish a mirage prop with additional cupping for lift and speed and being perfectly balanced to a high mirror luster finish is 250.00 plus shipping of 15.00. p.m. us at [email protected] for more info /Thanks again Darin Murphy
Propeller Technology
has greatly improved over the years, As far as speed gain ,I would be guessing if I made a statment.But the overall performace is better due to the rake is different and they are more progresivly pitched with a different blade patterns,YOU KNOW THE STORY "ITS ALWAYS BEST TO TRY, BEFORE YOU BUY".Darin
