Fast 22's
#101
got any progress cole. mine is still in machine shop jail because im poor. been out two weekends in a row on other boats an 05 malibu to do some barefooting on which it was extremely to cold to really enjoy, but needed to get a jump on the season. and my my dads 1985 230 weekender 350 alpha powered at the moment. hes owned it since 1996 and ive finally talked him into a big block bravo 3 swap this winter. i think we can make it go 50 haha.
#103
What drive height are you guys running on your 22s? (Prop shaft to bottom of hull) I am running a built 502/Bravo 1 setup, recently switched to 1.50 gears after the 1.36 blew up. Short lower with low water pickup only. I can't stay hooked up with any 3 blade I've tried, and I don't have much trim with my 26p Bravo 1 4 blade before it starts to let go at any speed. I get about 68MPH on GPS at 5100RPM, ~20% slip on the Bravo 1, and I'm not getting much hull out of the water. I'm thinking about trying a standard lower to keep me hooked up. Any thoughts on that? I'll have to do some measuring next time I'm out to see my current drive height.
#104
*Slide-
We have tried all of those things (shorty lower etc) and what works best is a standard length lower with a 3 blade mirage or tempest propeller. 1.50 ratio. Also, I recommend looking into some hydraulic assist steering to hold the drive firm while at speed, it helps a lot.
#105
#106
video of Bravo 1 with 3 blade 27p tempest at WOT
https://www.youtube.com/watch?v=1a1e3563WYo
I myself seems to be stuck at 82,4mph.
Have tried a bunch of different props. Best one so far is a Tempest plus 25P. (I run with 1,32 ratio)
#107
Nice I'm glad the tempest worked for you, I bet you notice a lot of bow lift and more trimming capability.
We haven't obtained a new top speed yet with the weather here at 95 degrees with 100% humidity it really effects the engine on the big end. I can run 86 consistently in those conditions. Might see some different numbers once the cool weather moves in. Get some video of your boat running!
#108
It works fine but I'm still hunting for more speed ;-) The fastest so far is 83,5mph. So making everyday 86 runs is still just a goal to aim for.
No videos yet.
I'm looking forward to see results with your 540
No videos yet.
#109
Hello I'm new to this site and am actively looking for a good Pachanga 22. After researching the Internet trying to learn more about the boats I discovered that the 22 hull may have experienced design changes during the 1986 - 1991 time period, and perhaps the hull got longer, wider, and a bit heavier beginning in 89? 1986 specs show length at 20.83 with a 96 inch beam compared to 1989 specs show at 21.17 and a 102 inch beam. Is iboats just out to lunch or are these specs actually accurate?
Additionally, I saw a post that claimed the stock 7.4 boats came with a different hull than the stock 5.7 boats. Not sure if this means anything either. Can any of you shed some light on this topic?
#110
