Fast 22's
#131
anybody still out there?
lots of good info in this thread
new to me 22, just picked up, 454/330, Alpha, Cleaver, 174 original hours
purchased from the original owner
the plan is to run it as is this season & upgrade over the winter
like to end up with a 70+ top speed
500-600hp, Bravo w/shower and hydraulic steering seems to be the formula
suggestions appreciated
#133
#135
Quicksilver 48 89802 A5 21P
Alpha drive with 1.32R
4400 RPM, best of 60 MPH (GPS)
454 Mag (330HP)
is there a better prop for top speed?
seems like we should be able to turn more RPMs?
I'd like to get as much as I can out of this combo for this summer, changes are coming over the winter.
Thanks for the help
Andy
#136
The speed is about right but your RPM is a little low which I'm guessing is because of the 1.32 gear ratio, mine was a bravo w/ a standard 1.5 ratio. The 330 hp engine is the peanut port cylinder headed motor with a cast crank. The Magnum 454 was a 365 hp engine square port head steel crank set up and I don't think many made it into the Pachanga's. A set of Dart Iron Eagle heads 308 cc with a HP 500 cam (591-601 lift and 226-234 @50 on a 112 lobe center) Edelbrock performer or Air gap intake w/ a good 750 Q series Quick Fuel carb, you'll need some Stainless marine exhaust and BAM you will run 74-75.
#137
are the stock crank & rods up to the task?
Andy
