tiger fuel leak >
tiger fuel leak
tiger fuel leak
Old 01-07-2018, 03:52 PM
offshoredrillin's Avatar
Received 1,339 Likes on 461 Posts
the thing about the tanks on them is if they are original, they have a bump out that leaks, also on an incline original hoses will split so gas can run out of them, just be safe, fumes are nothing to mess with
offshoredrillin is offline
Old 01-08-2018, 06:27 AM
Thanks, hopefully it is something as simple as a hose, but either way it will be fixed before it goes back on the lift.
dave krehbiel is offline
Old 01-11-2018, 07:27 AM
Starting to think if it wasnt for bad luck we wouldnt have any luck at all.
Hope its something easy......and cheap. At least you will have a kick ass shop to work on it.
-shane.
cabin fever is offline
Old 01-17-2018, 06:20 PM
Hey, Shane. I might have a place to work on it if the weather breaks and I can finish it.
Old 04-26-2018, 09:39 PM
Angry update on 42 Tiger Fuel Leak
Picture pretty much explains everything
Old 04-26-2018, 11:14 PM
Received 4,916 Likes on 1,389 Posts
Good times
ICDEDPPL is offline
Old 04-27-2018, 06:40 AM
Dan, were you able to pull those up and out like that? Or did you have to remove the bulkhead in front of the engine and pull them out the rear? (It may be different in a "gun")
frickstyle is offline
Old 04-27-2018, 10:43 AM
when mine were done at Rage Powerboats
Old 04-27-2018, 09:01 PM
not sure how long bladders last but honestly if I ever had to do surgery and replace tanks...I’d be tempted to cut the tops of the tanks and slide in bladders. Atleast the next time you change them out 6-10 years it’d be a simple job.
1MOSES1 is offline
Old 04-28-2018, 07:48 AM
Offshore, I see you did not put the bump out back in your new tanks, how much volume did you loose. Also, where was the leak, was it rot, or a broken weld. My glass guy says depending where the leak is, he may just want to do the one tank, but I am going to tell him to both. I am so sick about this, that I only want to do this once.
