Trans cooler dumps
![Default](/forums/images/icons/icon1.gif)
I'm trying to figure out the best way to dump my trans cooler water overboard. They are 3/8" hose. I see 3 options:
1. Send two 3/8" through hull dumps out the sides of the boat. Would be able to use much shorter through hull fittings.
2. Send two 3/8" through hull dumps out the transom of the boat. I would need to find a spot that doesn't dump all over all of my rigging just to keep things cleaner?
3. Send one 3/4" through hull with a tee out the transom. I'm not sure if these would fight each other and if one motor had a litlte more pressure than the other, it could it prevent the other from draining.
I'm leaning toward number 1 but am worried you guys are going to say it will look like a jetski or something
![Smilie](/forums/images/smilies/smile.gif)
![](https://cimg1.ibsrv.net/gimg/www.offshoreonly.com-vbulletin/580x435/80-p856163852_3_85137cc161f1e6c9533c042781ad087397a655c6.jpg)
I dump everything overboard off the side . Like you said shorter fittings and easier to access.
Once in a while you might get a question on why are your bilge pumps running all the time? lol
![](https://www.offshoreonly.com/forums/images/icons/platinum_member_star.gif)
ICD, are dumping any intake water ? I'm going to dump two -6 per intake to relieve the hot water issue in the rear of the intake
I recall that the side of the outlet was important on a trs transmission cooler. My boat has smaller fittings for the discharge. I can take a picture tonight for you. But its defiantly less than 3/8 fitting. My boat is all original with merc2 transmissions.
Slpcamaross97,
I understood the in and out to not matter on merctrans so would be interested in learning more. Makes sense to me that you are just running cool water through a set of internals to cool the oil so direction probably shouldn't matter? The lines on the in and out on the trans are 3/8" so I'm assuming 3/8" would be the dump.
Tom
![](https://www.offshoreonly.com/forums/images/icons/prop.gif)
![](https://cimg9.ibsrv.net/gimg/www.offshoreonly.com-vbulletin/2000x1504/img_1638_af045ba2e63eddd5d18af50a7ab8168da12bcf9e.png)
Here the way I ran them , my boat has merctrans, I ran the dump above the drives now they pump water on the drives as a drive shower.
^^^ you`d have to have higher pressure in the block then the headers.. otherwise there will be no water flow. Isn`t the pressure the same in both?
![](https://cimg5.ibsrv.net/gimg/www.offshoreonly.com-vbulletin/580x435/80-p1438180240_3_2f117b284af1a054ddfb47b619fabb43cbcda3d9.jpg)
I have two -4AN dumps above the drives.
That's what I thought at first, it would flow a little, just enough to get rid of the hot spots. I actually put restrictors in the black hose (1/4" drill holes) because the back of the intake and heads ran noticeably colder. I guess path of least resistance, it's pretty much open atmosphere in the tails with a vacuum pulling the water out the pipe.
![](https://cimg1.ibsrv.net/gimg/www.offshoreonly.com-vbulletin/600x409/res6_26a2a5b9b94cbc44ad8c1b94d06780d156b9ae83.jpg)
Interesting option but I can't figure out what kind of fitting will be long enough to go through the transom. Do you know what -4an fitting you used? Some kind of bulkhead mounted fitting?
