Turbine 101
#111
After I spent 3 hours making these it accured to me that I could have picked up the phone and called Trick Marine
And bought 4 boxes.![Roll Eyes (Sarcastic)](/forums/images/smilies/rolleyes.gif)
Ah what the heck I had nothing else to do.
And bought 4 boxes.
#113
Knot right
Do you have a job other than your boat? I really enjoy all of the detailed info you give us on this thread. Even though I have NO CLUE about trubines.
FWIW I think you are half way there....to becomeing a rocket scientist that is. Keep it up.
It also seems that you are going to beat some of your original projections of being on the water by Jan.
I dont know chit about them eithier.
Thats what makes it fun!
By the time we are done with this nightmare
we should know more about them.
#114
Special thanks to Ed Manion at Livorsi.
Great bunch of guys over there!
Got the other two already in the dash.
#115
Here is a picture of the fiberglass work.
It aint no Peter Hledin job but it should work.
This does two things it will redirect the Idle sound
to the lower ductwork and force it through the forward hatches when the flaps are closed.
Second it will focus the incomming air right into the custom
turbine intakes.
I decided to go with the standard water puppy to
circulate the water through the oil coolers. This is for
no wake and Idle only.
I am still deciding if I really need blow off valves on the strainers. Think about it we use them for piston engines
because your standard Big block head gaskets and what not
dont like the high presure. It dont matter with the turbines.
They have no water.
turbine intakes.
They have no water.
#117
The stainless plate helps deflect the air.
The turbine intake duct is retangular which meets
this hatch when closed.
#118
Here is some pictures of what happens when Turbines
are not done right.
are not done right.
#119
Here is some shots of my starters which cost
2500 each
These are the the 300 amp ones.
2500 each
#120
One of my Engines is complete and the other is almost done
and in the background.
Hopefully all will go well on the Test Cell this weekend.
