Turbine 101
#191
Me too.
Credit card! The American way.
Here are the custom Turbine sump tanks.
They hold the turbine oil and they mount directly to the
turbines.
I decided to put the buffer to them and shine them up.
Before and after pictured.
Also shown is the assembled crash boxes showing the
calipers with new brake pads.
turbines.
I'CE (01-19-2023)
#192
Its amazing how easy they polished up.
I had nothing else to do anyway.
#193
What day do you expect the engines and how did they ship them. When I had to ship my motors to Gellner I couldn't find a shipper that would insure them for more than 5000 each. We wound up driving them out and back ourselves.
#194
Yes this is the truth. Shipping insurance is maxed out at
5.00 per lb. on used goods. Atleast with Freight ABF.
I hate to even think about never mind post it on here.
Here I my engines When I shipped them.
Dean actualy gave me the idea for the tiedowns.
Alot of balls and no brains
#195
the inside view
I'CE (01-19-2023)
#196
PPS the turbine Builder uses FEDEX.
They do this for a living.
I will be pacing the floor wednesday.
![Party Smiley 004](/forums/images/smilies/party-smiley-004.gif)
#198
Thanks man!
My complimants to Jim and his Team.
Thank you for the expert service.
Not that I know squat about turbine building But
I would challange any other builder to come close.
Absolutly over the Top!
Well there here. I can tell you the pictures dont do justice
Everyone here at the dealership was all over them.
Now the real fun begins.
Now lets see if I can actualy pull this off
![EEK!](/forums/images/smilies/eek.gif)
#199
Tommaro I will buff the intakes and install the trans/crashboxes.
I took some quick measurements
Lenth:
The original holes on the engine mounting rails are 36 inches
away from the # 6 flange.
Measured from the first bolt hole.
The first bolt hole on the "can" mount on the turbine is 5.5
inches from where the bell housing mounts.The crashbox
is 19.5inches the drive shaft is 10 inches compressed.
This totals to 35 inches.
Height:
The centerline of the turbine ouput shaft to the bottom of the
"Can" (Container) mount is 7.5 inches.
When laying a flat edge on the engine rails in the Skater
and measuring 7.5 inches up with a straight edge centered
to the # 6 flange it is quite level.
Lenth:
Height:
#200
Jim took the time to label where everything goes.
That way any brain dead geek can install it.
Looks like I am going to need some O-ring to flare
double male adapters.
These are the fittings similar to what is used on Aeromotive
fuel pumps.
They are used on just about all fuel and oil connections
going to and from the turbine.
fuel pumps.
