Turbine 101
#291
Click on the above image and it will enlarge it.
the left side is in inch pounds.
The bottom is the actual mechanical pressure output that
is read on the dash Via the torque meter.
Does anyone know the rating of a number 6 drive?
These turbines can and will create enough torque to blow
the drive off the back of the boat
#292
1 Post
Those 6's will be groaning. The saving grace may be that they are not a direct drive to a crank shaft. The N2 is a free power unit.
I'll send you a picture of the drive shaft that snapped. looks like somebody neatly twisted it in half. If something had to fail the drive shaft is better than anything else in that drive line.
#294
See what happens to these toys.
Ya all should have seen the insides of them.
There were more teeth missing then a Montana
Red neck on crystal meth.
Well thanks to PETE at NopperMarine
There fresh and ready to be blown clean off the back
of my Boat.
Then ya call the west coast dude name Rik
at Arneson.
#295
bustin balls
I know I am a hack.... I promise to go and detail all the
wiring and clean everything for all you attention to detail
freaks.
ICE the sighn you asked about was the guys next door at the tranny shop bustin my balls about getting a Job.
They said all I do is work on my boat.
I told them I got my freakin prioritys straight!
freaks.
#297
Gerry,
I would love and come and see the project in person and give ya hand also if needed.
Any plans of working on it this wk. end ? The weather looks tolerable.
Can i contact you with an E-mail addy ? I don't want to sidetrack this thread any further.
When AMF had their O.L. Turbine on the Cape i was along side with camera . What a sound and thrill to see it run !
Ken Lessard
[email protected]
Ken Lessard
[email protected]
#298
ICE You have a pm.
Donzi ya got mail.
Here is where Im at.
Turbines wired up to the schematic I posted.
Ran the fuel tanks down to about 10 gallons aside.(gas)
Filled some of the cars up at the lot
Dumped some anti gel and fresh deisel in the tanks
bout 40 gallons aside.
Purged all the lines replaced filters.
Ran all fuel lines to the Turbines and returns back to tanks.
-12 feeds -6 returns.
Adjusted regulator to 15lbs.
Ordered two 0-1600 pyrometers from Livorsi.
The ones from summit only come with 10 feet of lead.
A little small. Ya need 25 feet in this boat.
These come with 1/8npt thermo couplers
They are being installed at aprox 1.00 aclock
at the combuster outlet.
All oil lines are ran with coolers. I will be filling
the sump tanks This weekend with the Jet oil.
If the weather holds out I should be able to install the exhaust
this weekend also.
Then maybe a test spool and fire em up.
Maybe I should get a video and post it.
I just dont want to look like a bonehead if something goes wrong
Donzi ya got mail.
this weekend also.
#300
Help from the audience Please
Here is the exhaust any ideas what the catch can
on the bottom are for????
Boy are these FUGLY.
They are big in diamiter and short however.
Gotta clean them up
Gotta clean them up
