Turbine 101
#331
Gerry, your "Right On" Ken great work on the video ! how is the custom built alt./power steering system holding up ? have you tested the brake/shift systems ? -SWEEEET no wind chill now !--
--J
#332
The Power steering has not been tested. lines not connected.
We are working out fuel pump issues. Wont hold prime.
No testing has been done on the caliper assembly eithier.
Basicaly 6:00 saturday we got em fired and bolted!
Ken would be pretty cool to video the caliper assembly
in action.
I,m almost out of water
#334
J
in action.
I,m almost out of water![Big Grin](/forums/images/smilies/biggrin.gif)
in action.
It really is a neat piece of engineering !
It got dark and it got cold, but when the Candles got lit it was impressive as all hell !
![Evil](/forums/images/smilies/evilB.gif)
<a href="http://good-times.webshots.com/photo/2577610710101021175fxYmMw"><img src="http://inlinethumb34.webshots.com/41761/2577610710101021175S425x425Q85.jpg" alt="skater 46 turbine 001"></a>
![](http://inlinethumb34.webshots.com/41761/2577610710101021175S425x425Q85.jpg)
#335
G, do u-have a little bit of lube in that p/steer/pump don't want it roasted like those stacks. Fuel prime? is there a dump after shut down or ck.valve/solenoid not operating in correct sequence? What does Jim say ? Water on the way by sat/sun for sure will load up the ol' Excursion to the gills ! As always best of luck/be safe and save some hot dogs and marshmellows for ken, ron, mike and the rest of the boat freeks !--J--
--will call 1st.
![Circle](/forums/images/smilies/circle.gif)
#336
Brotherhood #1
Gerry be happy to stop by and check out the skater. As for you J good seeing you at the boat show we'll all have to get together again sometime maybe a pre-boating party smetime before may
#338
I'll get some vid. of it working nxt. time !
It got dark and it got cold, but when the Candles got lit it was impressive as all hell !![Evil](/forums/images/smilies/evilB.gif)
<a href="http://good-times.webshots.com/photo/2577610710101021175fxYmMw"><img src="http://inlinethumb34.webshots.com/41761/2577610710101021175S425x425Q85.jpg" alt="skater 46 turbine 001"></a>![](http://inlinethumb34.webshots.com/41761/2577610710101021175S425x425Q85.jpg)
Its suppose to be brutaly cold this weekend.
We may have to kick them in the A$$ to heat up the lot
#339
G, do u-have a little bit of lube in that p/steer/pump don't want it roasted like those stacks. Fuel prime? is there a dump after shut down or ck.valve/solenoid not operating in correct sequence? What does Jim say ? Water on the way by sat/sun for sure will load up the rsion to the gills ! As always best of luck/be safe and save some hot dogs and marshmellows for ken ron mike and the rest of the boat freeks !--J--![Circle](/forums/images/smilies/circle.gif)
These are the Aeromotive fuel pumps. Nothing to do with Turbines. Kinda acts like a lift pump in a deisel truck.
They were mounted down in the bildge below tanks when
I ran the Blower motors. I had to move them . Too close to
Turbine exhaust. They are now above the tanks by a foot
and will not hold prime. I ordered some -10 aeromotive
check valves. Will try them.
Once we get all the issues worked out I can start putting all thes SS cushin clamps on all the spaghetti.
clean up and paint the forward hatches.
Still gotta test the braking system and wire the alternator.
Lots of things to do.
We got plenty of time
I can smell the dogs already!
![Party Smiley 004](/forums/images/smilies/party-smiley-004.gif)
#340
That's koool, as usual u-are on top of it, plumb before or after the- "act's like lift pump" -?-
__ ps that's great news, glad to hear, Ron is back on the job.
is that why u-r out of h20 ?
![Cool Smiley 027](/forums/images/smilies/cool-smiley-027.gif)
![Cool Smiley 026](/forums/images/smilies/cool-smiley-026.gif)
