Prop Slip 36 Skater
I have measured X Dimension I just don't remember what we wrote down. Need to measure again. Ran at 6000 for only 1 minute or so. Water pressure on 1 motor is tapped out (way too high) the other was at 25 lbs. 5500 RPM ran in both directions for 4 to 5 minutes each time so the 5500 is ran out for awhile. When AJ had the boat at 160 (the GPS says 160 still, I have had it at 146 during Desert Storm Poker Run 2 years ago) it was 1.24 gears and in Salt Water and would expect good tempatures. I always run in 100 degrees tempatures.
I never met anyone that had a "true" 1,000 HP that ran a "real" 160 mph. Lots of dock talk out there. I raced a guy 2 weeks ago 4 or 5 passes who had a 36 Classic Skater that claimed he ran 169. He had non branded motors with 10:71 blowers. He said he was making over 1,100 HP. Each time I passed him, he was topped out at about 145. If AJ ran 160, I'll bet he was making well in excess of 1,000 HP.
Don't claim to know why this 36 is not running faster but here is where I would look
Gear? What gear does it have now 1:24 or 1:35
Water pressure? If the water pressure is high that is one of the first things I would go after. Try the same props and raise the pickups. You can definatly loose speed there. Then try some with less rake (keep an eye on the H2O psi when changing props)
Rotation of the drives?
Down on power? He says they are fresh so should not be the first thing to look at.
You also may need to stay at 6000 for a longer period if you have the room. Just because the motors get there dose'nt mean the boat is done accelerating.
There is a lot to watch but try to notice if the MPH is still growing over that min of sitting at 6000 if so you've got more in there you just need more room
Mark
P.S. Aj did not spill his drink but did squeal a little
That was AJ's boat, He made 1030hp on our dyno compleat dress including trany. We ran 160 in lake pontchartrain, brackish water 90+ air temp New orleans humidity. 6400 37 herings 1.24 gears trim neutral, that boat did not need much trim but you need a "real" 1000+hp.
Mark
Mark
Was it like Ned Beatty in Deliverance?
Mark
Mark
16% is a bad slip #for a old V bottom!!!
Is this your first cat? just asking?
what did the rooster look like?
Most 36s like 24 ratio..
Something is way off !!!
4,444 prop speed should have you in the 155 range at least!!
If your running to much positive trim to get that RPM your down on power,, or the X is too high..
DOnt remember if that hull had tabs..if so they should be up at that speed..
Tabs are up, messed with trim and found a spot where it runs best speed. Could running 18 degree rake hurt the classic deck? Need to run the boat more of course but I just can't get out enough. It will be another two or three weeks before I can run it again.
