What are the Negative Issues with the 24?
What are the Negative Issues with the 24? I'm looking for one. I had been looking at 28's. I just wanted to know if the 24 had some quirks to it.
Most (all)Tunnels will porpoise and the 24 is no exception.My 24 will porpoise at around 50mph all the way through 65.You should not do any hard turning upwards of 40mph.Other than those 2 items it's the best tunnel out there.There really isn't a close second.My 24 with 450hp worth of Merc on the back will do 103mph.No other manufacture out there can touch that.
They're not red. The engines look like they could fall off at any minute. They have this big gaping hole down the center where Angela's cabin would go.
Now get back to work!
Re: What are the Negative Issues with the 24?
It Is The Best Cat You Can Buy For The Money
And You Can Learn To Drive A Cat Right If You Put In The Seat Time,
Don't Forget They Fly And Like Any Other Cat Can Have Your Lunch.
Be Safe And Wear Your Vest
Chris S
Chris S
