skater 28 W/ twin 2.5 Prop info
Can anybody recommend a set of props for this boat? What are the best props to use? The motors are brand new 2003 2.5 just looking for some suggestion on a good set of props and if anybody has a set or know where to get them. the boat is a 28 skater with 2.5's
Racer
![](https://www.offshoreonly.com/forums/images/icons/racer_member_star.gif)
they come with 1:87 wich are alittle faster top end but run and accelrate better with 2:1. On my 24 I have 1:87 because I am too cheap to pay to change them.
![Smile](/forums/images/icons/icon7.gif)
Hey Ryan.Idon't think you have Promax motors ,but if you do don't be so quick to change those gears.I took my 2:1 gears out and installed the 1:87's.The 2:1 gears spun 34" props all the way to the rev limiter so I had to ditch them.BTW the 34's now only go to 6,350rpm.So I'm going to try 3 blade 32's this weekend.
Thank you for the help this is the spec on the motors i just bought
Specifications
HP @ Prop: 280
kW @ Prop: 209
Max RPM (WOT): 7200-7500
Displacement (CID/cc): 153/2507
Bore & Stroke (in): 3.50 x 2.65
Bore & Stroke (mm): 89 x 67
Fuel Induction System: EFI
Ignition System: Inductive coil with computer control
Alternator: Belt driven 60 amp/846 watt w/voltage regulator
Gear Ratio: 1.87:1
Shaft Length (inches): 15
Shaft Length (mm): 381
Cylinders: V-6 (60 degree vee)
Fuel/Oil Ratio: 40:1
Recommended Oil: Mercury Performance Blend 2-cycle outboard
Fuel Requirements: 92 octane (R+M)/2 leaded
Rotation: Left or right hand
Warranty: One-year limited warranty for recreational boating and 3-year limited corrosion warranty
Weight (lbs / kg): 375/170
Specifications
HP @ Prop: 280
kW @ Prop: 209
Gear Ratio: 1.87:1
