Props for 31SS
Kevin, since you've run both stock and labbed 28's, so you have an impression on whether the 496HO's run better at lower or higher RPM's? Which prop gave you your best speed?
Zo6 You Stated That You Had Your Hull Brought Back To New Condition . Was That A Total Blueprinting Or Just A Little Straighting Here And There. Is The Bottom Perfectly Straight Know If So How Much Was It Out?
We did not check the hull for staightness with a straight edge. However it looked quite straight by eye once cleaned up.
The labbed 28's I ran were the best......i was right between 5K and 5100 and it seemed perfect.
My problem is where i boat - it can get shallow on the chain, so i need the added strength of the non-labbed prop. I will run the labbed props in lake michigan.
Anyone trylabbed 30's.......????
so you guys trim up tp 6-7 on gauge? I was always scared to trim that high , I was only trimming to about 4-5? what are you running tabs at ? I run at 6 the neautral position. I have 28labbed on right now and at those settings I am at 5,000 wot.
Yes, my boat seems happiest at 7. I slowed down below 7 and started to slip above it. I had my tabs up.
