31ss who's running what prop???
The infuson hasn't impacted ride quality at all and the twin 496HO set-up is economical from a purchasing, maintenance and operating perspective. I made a previous post on speeds with different engine configurations but with that package optioned out conservatively high 70's to low 80's out of the box. Again that has to be prefaced with speeds as seen here in the mid-west... in coastal areas you will probably see more.
Ken...nice numbers bro!
Charter Member #655
Cougarman Now thats runnin!!!is that Thuner Marines poker run?
Ken what are you running for a drive? is it standard length?could you benifit from a shortie? Thats haulin a$$
If your boat has a sail do you ride a horse to the ramp?
Charter Member #655
I was in the last one I think it was 1995...took a hell of a beating from Holland north 3-6' sea's I had a 25 Checkmate at the time...sure was a great time!!!
I'm running 3 blade mirages on alpha ss drives(2'' shorter than std alpha), and yes the holeshot/getting on plane is a little weak, but once the props bite it goes.
My speed is way off (I had one lean motor that had two dead cyl and the heads on the other were mismatched)oooppppsss! Bought it that way, I didn't know there was a problem untill one pulled 5200rpm and the other would only manage 4200rpm
but still managed to run 65gps with Merc racing 5.7l 320horse efis.
Lets see what two brand new motors and efi set ups will do this year. It's gonna be hard dodging ice flos on the CT river though.
Sorry I forgot it's an 87 30SS, which is the same hull as the 31, LOA is 301.5
